In Octavia 2 1.9 TDI PD 77kW two brands and two sizes of Dual Mass Flywheel are used, LUK and SACHS with diameter 220 mm and 240 mm.
The VIN number will tell which one is in your car.
Can be replaced with the one-piece flywheel. If it fails prematurely.
How to tell it is a faulty DMF: Here
Part numbers:
038 105 269 D - flywheel
038 141 025 N – pressure plate
038 141 032 – clutch plate
N 101 01001 – bolt pressure plate 6x
N 902 06103 – bolt flywheel 6x
Part numbers:
