I know the Jettas have this, but a friend playing with his new Octavia RS spied it in the manual. From memory you put the mirror on L, put the car in reverse and set the angle you want, then when you put it in any other gear it should move back. Well that doesn't happen so I guessed it must be only with the electric memory seats....but then realised the Jetta doesn't have that as standard...so does anyone know if it should or shouldn't work.
Auto reversing mirror tilt
Most discussion is Golf/Jetta based and the general consensus (for Golf Vs) is that you need the electric seats with memory for it to function. IIRC l read a mention somewhere that you may be able to get it to work (via VCDS) on a vRS if it has factory installed rear parking sensors - but haven't heard of anyone actually getting it to work on a vRS so far. It certainly would be nice to have
Please let us know how you get on.2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
Instead of changing gear try switching the mirror knob to O instead, coz the system is designed not to return left mirror to original position when you change gears in slow speed under 10-15kph (for example to move back-forth in completing a reverse parking) http://www.vwwatercooled.org.au/newf...7&postcount=32Originally posted by woofy View PostI know the Jettas have this, but a friend playing with his new Octavia RS spied it in the manual. From memory you put the mirror on L, put the car in reverse and set the angle you want, then when you put it in any other gear it should move back. Well that doesn't happen so I guessed it must be only with the electric memory seats....but then realised the Jetta doesn't have that as standard...so does anyone know if it should or shouldn't work.2006 MY07 Jetta 2.0 TFSI Reflex Silver, DSG, Sunroof, Bi-Xenon, Leather
Only Jettas with factory parking sensors have the memorised tilting (regardless of electric seats) - it's pretty handy but i've found it never returns its original position once finished.. It always stays about half way down or lower than originally set!!2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
2010 RS Wagon
Hi,
Bringing back an old thread.
Any current owners of the RS Wagons care to clarify??
I cannot seem to get mine to work. I had F/R Sensors btw. Dealer mentioned that car is equipped with this function when I picked up the vehicle a couple of weeks back but had not have time to play around in the car till now.
Any advice please. Thanks
But did pre-FL cars actually have it? The owners' manual says so but....Originally posted by K1W1 View PostThere is no mirror tilt on my10 Octavias you dealer should know better.
It was quietly dropped when the facelift was released.Mine: Silver 2006 Volkswagen Golf Sportline 2.0FSI 6M (with a sunroof)
Parents': Candy White 2008 Skoda Octavia RS 2.0TFSI 6M Liftback
I think it only happened on cars with the electric memory seats, from memory only the Jettas that have that, had it as well. I don't know anyone with an Octy who got that fitted, but to date, also have never heard of anyone having it work on any Oz Spec Octy.
Just to clarify how it works... (in my jetta with rear sensors no electric seats anyway).Originally posted by woofy View PostFrom memory you put the mirror on L, put the car in reverse and set the angle you want, then when you put it in any other gear it should move back. Well that doesn't happen so I guessed it must be only with the electric memory seats....but then realised the Jetta doesn't have that as standard...so does anyone know if it should or shouldn't work.
You select "L" position on the switch. Put it in reverse. Mirror will now move down on its own you do not adjust its position yourself. Reverse car out of driveway. Put car into Drive. Take off and get above about 20kmh mirror will now return to roughly where it was before tilting.1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
Thanks all. That is what I thought, would be good to have as wife would be driving it with baby fairly often.....not sure how long the alloys would last this wayOriginally posted by woofy View PostI think it only happened on cars with the electric memory seats, from memory only the Jettas that have that, had it as well. I don't know anyone with an Octy who got that fitted, but to date, also have never heard of anyone having it work on any Oz Spec Octy.
Anyway something OT. Anyone actually manage to fit an OEM / VW / Audi RVC into an Octy Wagon??
Been reading the VW threads on this that uses an integrated Audi trunk handle and camara part and not sure if those options would fit the Skoda.
