I've been letting the car idle for a few minutes especially on hot days....or after a long run, but notice this causes the fans to come on after switching off the car for quite a while on a hot day.
I've always assumed this is normal, as any car left idling for a while tends to kick in the fans due to the lower air movement.....just from what someone said on Briskoda, I just want to check everyone else sees this?
Its always a bit of a compromise, as you should let the turbo cool down, but when there is low airmovement and the car is just sitting in a hot air at the moment, all the heat gets transferred to the radiator and intercooler, which prompts the fans where normally on a hot day you try and avoid idling.
