Well, I finally have a working extra spare key (with working remote).
It has been quite a saga, so I thought that some of you might wish to benefit from my "experiences". I haven't described the components of keys (and their functions) in great detail, as this has ben covered in other threads in the VWWC forum.
I prefer to have 2 spare keys for any car I have, so after I got my RS I started looking for an extra spare and remote. If you happen to end up with no keys your car will be dead in the water, as no one, not even the dealer, can get you going again until you get some replacement keys from overseas. It is literally a tow-away job, and breaking windows if you absolutely must get something out of the car ! This is good security as long as you are aware of the ramifications.
I had already been through the hoops getting working spare keys for my Transporter, so I knew that the cheaper options (ie buying from anywhere except the dealer) is a bit of a challenge, and so it turned out
Firstly I sourced keys and remotes from two different (cheap) suppliers on fleaBay. They were able to give me "Skoda" keys and the correct remotes, but the key halves had the wrong transponders for a 2008 build Octy RS.
I had the blank blades cut at a local locksmith (one with a computer cutting machine). That was fine.
So then I looked around a bit more. As always, getting the correct transponder (immobiliser chip or RFID - small, like a glass grain of rice that lives in the key half, not the remote half) is the difficult problem to solve.
I found some transponders that were the correct model, but it seems that Skoda (like VW) is now "pre-progamming" these transponders so that they will only work for a specific Make AND model, and once they have been adapted to a specific car they cannot be used for any other car.
So far, none of my transponders (fleaBay or aftermarket) would work on my Octy.
Next was a UK supplier who believed he could get a lock set (which included 3 locks and two keys) to suit my Octy for GBP 120.00 (not too expensive, as the $AU was flying high at the time). Alas, the transponders in these didn't work either (I suspect they would be OK on an earlier build Octy II).
By now I was getting fed up with buying stuff from overseas that didn't work, so it was time for the option of last resort - buy one from my local Skoda dealer.
I only purchased the "key" half, as by now I had plenty of extra remote halves (and I had two of them coded to my car and working at this stage). This key took several weeks to arrive, as they have to come from overseas (the blade comes pre-cut to fit your locks) The RRP for this half is around $222.00, and I had to pay another $60 for key coding (VCDS can do this if you have your 4 digit PIN or SKC, otherwise it is a dealer only job).
Remember to have ALL your keys with you for coding, any left behind will no longer work - your car will start OK, then the engine will cut out after 1-2 seconds with the immobiliser symbol flashing.
So, after all this, my advice is:
1 Don't lose your keys, they are precious and difficult to replace.
2 If you want a spare, buy the key half from your local dealer, and buy the remote half from fleaBay (or me, I have 2 "spare" spares).
3 If you think you may end up locking your keys in your car (very easy to do), it is fairly cheap to get a "dead" (ie no transponder) key, and hide it somewhere on your car's exterior (please, be creative about your hiding spot, otherwise you may find your insurer asking awkward questions). This will allow you to get into your car, but it can't be driven away with this dead key.
If anyone has questions or comments, feel free to do so.
Hope you all have a great 2009.
