Hi all, For those who enjoy a detective mystery, I'm hoping to get some ideas about a recurring problem with a 2015 VRS so I can discuss with mechanics. For the last couple of months the car has been cutting out. It originally happened now and then when idling. I wondered if it was the start stop being a bit eager, but turns out not.
We don't tend to idle for long before pulling off so it didn't happen much until one day about a month ago the car cut out while driving. Given the concerns I took it straight to our local mechanic who got lots of BCM faults showing and a low 50CCA reading from the battery so he replaced it. It drove OK for a few days until cutting out when idling started again. This time I took it to our Skoda dealership who found also unrelated oils sump and coolant leaks and did a service. They claimed some kind of pin or such like was loose and they removed and cleaned it or something and that was the fix for the cutting out. I found this was not described on the invoice so can't give the details yet.
The car drove beautifully the next day, but the day after it cut out several times at lights and once in motion for my wife on the way to work. Luckily her route passes the local mechanic so we left it there again. I went down and the mechanic saw the cutting out while idling for the first time. The pattern is idling can be smooth for a bit and then can get rough, or can start rough. Either way it can then be fine or go juddery (very rough) before cutting out. There seem to be levels of rough and it can go rough to smooth and back. Hearing it he instantly thought it was more likely mechanical than electrical. He put some fuel system cleaner in and it made no difference. The final step was he kept the car while waiting for his parts place to open after Xmas and saw the same problems every day when moving it and kept getting a reading for a camshaft sensor fault so replaced that. Of course it drove like a dream during his test drive. When I picked it up yesterday I felt a bit of roughness in the idling, but it behaved and got smoother. Until my wife drove it this morning and it cut out 3 times in motion within 1km. When I drove it home it was happening every 100 metres or so. But it did get better after a km or so, and so I added a trip round the block and it didn't cut out!
I'm now $1,500 into this with the local mechanic and $4,200 with the Skoda dealership - though only $160 of that was for supposedly fixing the cutting out, what it went in for!
Any ideas on the mechanical or electrical side? Before getting the camshaft sensor code repeatedly, the local guy said it could be a rusty fuel tank, rare but fits the pattern in his view. I do wonder if the random periods when it runs well or badly combined with it getting worse over time could fit the idea of rust moving in the fuel unevenly. There's not been a single moment where the car failed to start btw.
Don't really know what to do now. Once more the car is undrivable on a Saturday or public holiday when I can't just ring Skoda. Clearly this is a dangerous car that needs fixing and somebody, probably Skoda needs to get to the bottom of it, but I don't have any experience with this kind of situation. I can wear the cost so far. From now I think the manufacturer should take some responsibility to solve the problem. So any thoughts about how I go about that also appreciated before I pick up the phone.
