I've had my 2011 Octavia VRS wagon (petrol) for over 2 years now with no issues. A couple weeks ago the car would not start due to a dead battery. Initially thought the battery was on its way out as it was a few years old so purchased a new battery. A couple days later, same issue, the car would not start and the battery was dead.
After fully charging the battery up, the car lasts between 2-3 days without being driven before its completely dead (not even enough power to remote unlock the doors). At this stage it goes from 13.3V to under 11V.
I've had a multi meter hooked up in series to check for a parasitic battery drain and the results were strange. After waiting around 20 minutes with the doors locked and the bonnet open, i can see the car goes to 'sleep' with a reading of about 20mA (good). It does this for 2 1/2 minutes, then spikes to almost 4A for 30 seconds! Then back down to 20mA for another 2 1/2 minutes before spiking up to 4A again for another 30 seconds and so on. My understanding is something must be having issues talking to something else correctly and every 2 1/2 minutes it checks again to see if it can talk, if not, tries again in a loop?
Anyone experienced anything similar? I know I should be checking which circuit is the culprit but the issue is it only occurs for 30 seconds at a time, so will need to be quick in checking each fuse and then moving on. Any suggestions on another approach?
Appreciate any input!
