Fabia vRS Combi 312mm brake conversion
  • Fabia vRS Combi 312mm brake conversion
    Hi folks, just thought I'd share my experiences of putting the 312mm fronts and 256mm rear brakes on my 2013 Fabia vRS.
    I picked up some used front brake calipers with carriers on a popular internet auction site along with a set of rear calipers and carriers to suit the 256x22mm rear discs. These parts came off a US Mk4 GTI Anniversary Edition but I think a lot of Jetta's also had these brakes, they even come in red! I also managed to get hold of brand new front and rear discs and pads locally for a very good price.
    The front brakes are very easy and don't amount to much more than a straight unbolt and bolt on the new bits, a couple of observations, I could've used my existing calipers and just swapped over the caliper carriers. I had read elsewhere that the Fabia 5j needed the calipers as well as the carriers but at least for my car this is not the case. Also I tried fitting the larger brake dust shields to keep everything OEM looking but the shields I found have a different bolt pattern and don't fit. You don't really need them but I may investigate further in the future. The front brake lines bolt straight up but I'll change them for braided lines soon as I think the originals are just a touch too short but that's probably just me being fussy.
    The rears are a little more involved but only slightly so, you can apparently fit bigger dust shields on the back but it involves removing the rear bearings and I decided not to bother. So arm yourself with a trusty angle grinder and trim the outer part of the original shields to make room for the 256mm discs. I also sprayed mine with some matt black hi temp paint just to make it look neater and stop any rust forming.
    I rebuilt the calipers I bought for the rear as they weren't in quite as good a shape as the fronts I bought, so new seals, slider pins and anti rattle clips.
    Bolt it all up, bleed the brakes and you're good to go.
    If you're unhappy with the standard vRS brakes and you want to fill up that wide open space behind your wheels then I highly recommend this upgrade.
    Like your work group 3.
    The standard brakes are at best average on my RS combi too.
    Would you say the biggest improvement is in stopping power or having less brake fade? Also are the rear discs vented?
    2012 Fabia II VRS Estate - APR stage 2 tune, Custom 2.5" turbo back full stainless exhaust with ceramic coated dump pipe, Harding Performance Cold air intake, Wagner Tuning Competition Intercooler, GFB DV+ diverter valve, Braille B2317RP battery, Eibach pro kit springs, Bilstein B8 shocks, Harding Performance F+R ARB, Super Pro bushes, Porsche 986 Boxster S front brake calipers, 330x28mm front rotors, Ferodo DS2500 front pads and Remsa rear pads, Enkei RPF1 17x8 et.35 with 235/40R17 Yokohama AD08R tyres, Maxton front splitter and Superskoda fender flares.
      Yep I hated the long pedal and feeling like it was never going to pull up in time, reminded me of a few Merc's I've driven all the braking occurs in the last few cm of the pedal travel.
      It just feels more positive on the brakes and gives you more confidence, it'll definitely have less fade because there's so much more metal to heat up compared to stock but I'd say the extra stopping power and feel is the biggest improvement.
      Yep the rears are vented.
        Any pics?
        Skoda Fabia vRS
          I know what you mean about the feel. It is scary under hard braking sometimes wondering if it will pull up. So I have to say I don't test my luck. I have to say I am mostly interest in the rear brakes on your car as the front is a pretty standard upgrade. One thing that I would like to know is if the rotor is a bit thicker around the stud pattern as I would like to widen the rear track without using spacer?
            I'll sort out some pics when I install my new springs and shocks, possibly over the weekend.
            Yep the fronts are really a no brainer, I'm pretty sure the 256x22mm rear rotors don't add any track width.
              Put some 17 x 7.5 wheels with a ET 35 offset so the front wheels are now flush with the guards. Add to that the Eibach 30mm lowered springs and it looks much better.
              Have heard of the front brakes being transferred to the back before if you like to go bigger. Also something about Audi TT rear setup too.
                Good job on having a go mate, you will most definitely get a good visual upgrade as well as heat dissipation under repeated long hard stops. However the better pedal feel will be down to the new fluid and pads rather than the actual increase in rotor diameter. Not trying to sound like a troll, just trying to help a brother out here but most likely if you changed your fluid and put better pads in the Fabia to begin with, plus a tweak to the brake pedal response with VCDS and you would have got far better performance gains. In total you have probably added a further 7-8kgs of unsprung mass to the car and decreased your braking performance at the front end because if you didn't change over the caliper as well, you are still left with the lesser of the 2 288mm calipers regarding piston diameter. Basically, rule of thumb for the best brakes you can fit to your car is this: the smallest and lightest you can get away with, coupled with the best pads and best fluid you can afford.
                  I think you're putting a lot of faith in brake fluid and pads if you really believe that makes all the difference, I used ordinary off the shelf Dot 4 fluid and a set of everyday Bendix pads. I tried the VCDS change and wasn't overly impressed and yes I did replace the calipers.
                  I think you're ignoring the increased leverage effect that the larger discs have on braking performance and feel.
                  About the only thing I do agree with in your post is the increase in unsprung weight.
                    I don't know about the fluid but good pads make a massive difference to braking ability. Because you haven't increased the swept area of the pads the gain made from bigger disks is around 8% - you would have got that from better pads alone. The change in pedal feel is likely unrelated. It will definitely look better though.
                      The change in pedal feel is entirely the point of going to the 312mm and 256mm discs, I doubt that the car stops in much if any shorter distance than before, my gripe was that the standard brakes have a very low bite point before they really seem to do any work. Better pads probably would've improved it somewhat but I doubt it would've given me the same results.
                      But if you don't want to take my word for it this is what AP racing have to say on the subject;
                      AP Racing Formula Brake Kits come supplied with large diameter discs. The ventilated discs have either 24, 30 or 48 cooling vanes depending on the application, to draw air through the centre of the discs. They are handed left and right, and are cross drilled or grooved, again, depending on the application, to allow gasses that build up on the surface to escape. Where cross drilling is used it is more restrained than on the face of our full race discs, as pad longevity is more important on a road car than weight saving. The discs are wider and of a larger diameter than standard. The extra material controls heat build up and the larger diameter means that the caliper can be mounted further away from the centre increasing the leverage effect, which increases braking torque while decreasing effort required on the pedal.
                        Yup, about 8% less. You would have got the same effect with better pads.
                        I'm not saying it's not worthwhile - if you combine the bigger rotors with better pads you will have a great track day setup as the improvements will add together and as you say they look better I'm just pointing out that there is a cheaper easier option for others.
                        Personally I don't think there is anything wrong with the stock pedal feel but with brakes you need to be comfortable that they will do the job
                          Your pedal feel is dictated by the electronics that the car sends back to the pedal. I have driven 3 6r polo gti's and 2 had great pedal feel and the last was rubbish, all in stock setup but with different software versions. Same as the steering weight can be adjusted, brake pedal feel can be adjusted.
                          Yes, I put MASSIVE faith in just fluid and pads because they are the 2 major factors in making you stop shorter for longer.
                          Yes you just bought generic DOT4 fluid off the shelf and bled and refilled the reservoir but let me ask you this... How old was the brake fluid to begin with that you drained out? Regarding pads, bendix make pretty bloody good pads for the coin and VAG pads are more oriented at comfort and refinement rather than performance so you don't get squealing etc.
                          Yes the ability to have a stronger handle force will retard the rotation quicker but the extra weight that has been added will offset this effect. My tip would be that when you get some free coin, buy some lightweight 3 piece rotors with aluminum top hats. You can save up to 3 kgs per corner just by going to lightweight hats. This will help offset the fact that you have added all the extra rotational mass which means that the car is working harder to spin those wheels. Like adding bigger tyres on a 4x4 makes it considerably easier to snap axles, adding bigger discs makes it harder to spin the wheels.
                            Yup, about 8% less.
                            Its a funny debate / idea, personally I think the added weight is worth it. Addition of unsprung weight is only relative to the front wheels as its a fwd car.
                            I have 312's on the front of mine, have tried a few different sets of pads, etc. about to do the rears, I ended up with quattro carriers for the rears which don't fit (not even with the ECS spacer kit), propper ones just arived this week. I understand what people say about changing the pads, fluids, etc, but IMO the feel of the 312's is totally different to the stock front brakes which felt rubbish, even with better pads. Looking forward to the balanced set.
                            I don't agree with the percentages, or examples of what works on another car (eg software tweaking, I've not tried on mine). Brake feel is something somewhat personal, how do you measure feel in a percentage? I know when I use my brakes I barely have to touch them to quickly stop, worth the money over the stock system which always felt inadequate. The stock system could pull up just fine, but for feel and tracking (where the repetition of heat buildup makes little differences feel huge) the added bite really helps. Again, each to their own, the fastest Polo @ wakefield (owned by a person, not a tuning company) runs stock brakes with better pads, fluids, rotors, etc. There is much more to brakes than the rotor size, if I really wanted to do it properly, I'd ditch the basic single pot floating caliper design for something like the porsche 6 pot design (sexy and bitey).
                            Each to their own, for less than $1k I have a fully upgraded braking system to my needs, some will spend that on a nice set of pads, fluid and rotors.
                              Well I for one think you've improved the car and given yourself scope for further improvement down the track if need be.
