Finally got my hands on the RS Combi. Very happy, but I cannot get the Bluetooth to pair with my iphone5. Any ideas?
Setting up Bluetooth in RS
 Had the same problem a few weeks ago when I picked up my VRS combi too (but i'm using andriod). First up check to make sure you have your bluetooth is enabled on your phone in your settings. I think I then only had a 2 minute window on my phone once I made it visable to other devices to make the connection. From the car side I think it is 3 minutes after you start the ignition to find your phone. Then just follow the prompts and you manual and you will be pretty close.
 The next question you may have is how to get out of the phone menu. Just hold the up selector button down for like 3 seconds on the end of the right hand side wiper controls. This should get you back to the normal MFD screens.2012 Fabia II VRS Estate - APR stage 2 tune, Custom 2.5" turbo back full stainless exhaust with ceramic coated dump pipe, Harding Performance Cold air intake, Wagner Tuning Competition Intercooler, GFB DV+ diverter valve, Braille B2317RP battery, Eibach pro kit springs, Bilstein B8 shocks, Harding Performance F+R ARB, Super Pro bushes, Porsche 986 Boxster S front brake calipers, 330x28mm front rotors, Ferodo DS2500 front pads and Remsa rear pads, Enkei RPF1 17x8 et.35 with 235/40R17 Yokohama AD08R tyres, Maxton front splitter and Superskoda fender flares. - APR stage 2 tune, Custom 2.5" turbo back full stainless exhaust with ceramic coated dump pipe, Harding Performance Cold air intake, Wagner Tuning Competition Intercooler, GFB DV+ diverter valve, Braille B2317RP battery, Eibach pro kit springs, Bilstein B8 shocks, Harding Performance F+R ARB, Super Pro bushes, Porsche 986 Boxster S front brake calipers, 330x28mm front rotors, Ferodo DS2500 front pads and Remsa rear pads, Enkei RPF1 17x8 et.35 with 235/40R17 Yokohama AD08R tyres, Maxton front splitter and Superskoda fender flares.
 Use the car's phone menu to initiate pairing
 On the phone, search for blue tooth devices, select the car when it appears, enter the pin
 (I think my car was configured with a pin of 0000)2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
