Apparently, there is an update to the DSG software on the Fabia RS in Australia.
Don't believe it is performance related but may have something to do with a warning light code or similar. Not that I have ever seen one issue or one light come on in 6000ks.
Will be performed by dealer just after Christmas, so I expect I will be able to find out more then.
Anyone else know anything?
Wish it had something to do with a smoother 'breakaway' from zero velocity, car is consisitantly tricky to either not bog down or launch too hard. Seems it loves a firm prod on the right pedal and has impressive acceleration after the initial take off, if driven that way. However it is tough to just smoothly roll away, without a slight hesitation.
Add painted white lines and water and good luck about pulling away fast, although credit must be given to the Traction Control as long as you remember to not turn it off if you are front row at the lights and it is raining.
Cheers all
Cheers all
