G-8VXWWTRHPN seat toledo 16v - VWWatercooled Australia
seat toledo 16v
  • #16
    The Toledo has the earlier OBD 1 type connector.
    2 Plugs, one blue, one white.
    They are either behind the switch blank next to the headlight switch, or behind the map pocket by the drivers knees if they have become detached.
    • #17
      Hey loon,
      I just realised that the rear left power window switch was busted. Have you got any or would you be able to get hold of one?
      • #18
        Are you sure its the swicth and not the mechanism?
        • #19
          yep the spring in the switch seems to be busted too and its just hanging down at this point and i cant seem to find any parts anywhere for this.
          • #20
            I`ve got a switch for you. Call me at work and give me the list.
            • #21
              The motor takes a few kicks before it turns over? Loon you have the same car is this normal? we've tried different batteries and its still the same
              • #22
                Front LIghts
                Are the lights for the toledo taken from the 96 Passat?
                if i want to put in clear lights at the front would i be able to use a housing from a vw aftermarket lights provider?
                • #23
                  Couple of turns is normal. Starter could be to blame, its the same as VR6 manual, and expensive.
                  Front headlights are unique to Toledo. What do you want? Clear front blinkers? or headlights?
                  • #24
                    i was looking for the headlights , the blinkers i can find on ebay but nothing for headlights though... i have to find out whats wrong with the motor first since its taking a long time to kick over and it seems very slow. i have tried different batteries that i knew were good but it does the same thing , its very slow to turn over but it doesnt happen everytime either just happens sometimes. any suggestions .. im thinking it could be the starter motor since ive already put new plugs in and since the car does not miss once its on i guess theres nothing else i can think might cause the motor to turn over so slowly
                    • #25
                      Check your battery earths mate.
                      A fat cable from the earth of the battery to the bolt of the starter usually does it.
                      • #26
                        electric supercharger
                        Hi,
                        I've been looking at electric superchargers.. does anyone know if there is any real performance gain by installing one on the tolly?
                        • #27
                          Use a toyota MR2 Charger!
                          • #28
                            does anyone know how much a mr2 charger would cost?
                            • #29
                              Depends how hard you want to work ie running around. Should see 40-50hp for $1K
                              • #30
                                where can i find cheap seat parts online? does any one know any reliable sites i could may be purchase parts from?
