SEAT Brake Pads
  • SEAT Brake Pads
    G'day,
    Just wondering which front brake pads fit on a 95 SEAT Cordoba, I have read somewhere that VW Golf MK3 has equivalent pads, any thoughts??
    Highly likely, if your discs are 256mm the pads will be the same as a MK3 Golf GL.
      There are different pads depending on whether the discs are vented or not.
        upsell Mattie
        german - english translations esp vw documents!!
        Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
          Originally posted by karmen View Post
          upsell Mattie
          Oh, I can help him, but he hasn`t posted location or added any further info.
            not pads
            knew it
            just tell me in a 'keyless' entry car (Cordy 95) do they pull out all the door lock mechanisma?
              Originally posted by Haganstar View Post
              G'day,
              I'm pretty sure th brake pads are not vented
                You will get the wrong ones unless you are CERTAIN.
                Check the front rotors, are they solid or vented.
                The pads are the same, but the non vented onew are fatter so as to take up the space and cannot be used with a vented disc.
                  Not so much the pads as the discs themselves. My wife's 95 Cordys discs are vented so your may very well be.
                  There is is pic of a vented disc on this page:-
                  Disc brakes are the most common brakes found on a car's front wheels, and they're often on all four. This is the part of the brake system that does the actual work of stopping the car. Find out all about disc brakes -- even when to replace the pads.
                    SEAT Brake pads
                    Hey,
                    I have checked the brake disks on the front and they are solid disk brakes
                      No worries, I know the pads you need. I have ome in stock for $77.
                      Call me at work tomorrow if you want em
                        SEAT Brakes
                        Hi There,
                        Thanks for the responses....however I am just after the Part No. for brake pads (solid disk) either SEAT or VW no. I am located in Melbourne
                        Ta
                          im in the same boat but for my 95 ibiza GTI what pads do i need and can i buy them at super cheap? And how hard are they too change? Im 19 i dont know how to do alot of stuff on cars i just read about how to do it so sorry for noob question.
                          Pizza delivery Seat!
                            Hi mate,
                            The best street pads for your car would be something like Remsa. Very similar to TRW Lucas, and a great all round performance street pad. Fronts are $89, and rears are $65. Not sure what Super Cheap would stock at it's fairly specific European stuff, and if it's only Ferodo that they can get for the Seat, then look elsewhere, as they're just not worth the dollars.
                            Regards,
                            Greg
                            GSL RallySport 1300 884 836
                            Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
                            QFM Performance Pads
