Originally posted by DVR68U
View Post
Drive shaft bolts
Thanks for that, Brenton.Originally posted by DVR68U View Postits not a allen key head and not a spline head. its a triple square (+other ones pete said) head bit. thats why yours didnt fit you must have had the spline in 8mm which is different.
That makes it a clearer for the struggling old brain.
I just measured the XZN '12' I got from Snap On and it is actually 11mm across the splines.
If that convention holds true the XZN '8' that I had (and should have again this arvo) must be 7mm across the splines which is what I measured the internal head spline to be.
That being the case it will fit.
Call me presumptuous but I have always thought that M8 meant "Metric 8mm".
As the haze of confusion clears I'm getting a lot more comfortable with the whole thing now
edit: Just phoned the Snap On guy and got him to measure the XZN '8" and it is indeed 7mm across the splines. Sorry for the storm in a teacup guys but I've certainly learned something from it.
edit2: As a by the by, I measured the XZN '6' and it is in fact "6mm", lol.
I suspect you're not measuring them correctly.
My recollection is that an M8 is 8mm between opposite corners of any of the three squares. If you're using verniers to measure, rotate the tool to make sure you're reading at the widest point. Same logic applies to the other sizes.
Bear in mind that the tool is most likely slightly tapered too, you might need to take the measurement further up the shaft.
Tri-square and xzn are the same thing.
Spline, allen, double hex, torx, polydrive, bristol are all very different things although they might look similar.
I have a set of bristol bits but I've never found a use for them. Anybody actually seen these in the wild? I think these are also called RIBE bits.
I'll measure mine up tonight, I'm kind of curious now.
Pete79 MK1 Golf Wreck to Race / 79 MK1 Golf The Red Thread / 76 MK1 Golf Kamei Race Car
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Fair point, PeterOriginally posted by Peter Jones View PostI suspect you're not measuring them correctly.
Across the points and 2/3 up the spline of the '12' I make it 11.5mm - which is reasonable allowing a clearance in a 12mm socket.
Same distance up the '8' I make it to be 7.1mm or maybe 7.2mm
Always happy to hand out homeworkOriginally posted by Peter Jones View PostI'll measure mine up tonight, I'm kind of curious now.
