OK I got a 95 SEAT Cordoba automatic with a 1.8 8v adz motor.
It started during winter with the heater not working but everything else was ok.
Now that spring has come the car overheated and i found that one of the welch plugs had rusted out.
So i replaced the welch plugs.
Started the car and it still overheats with water leaking from the 2 plastic head flanges.
Replaced the 2 head flanges.
Still overheats. Removed the thermostat completely to see if it would run cold.
Still overheats and is doing it at the same rate as if the thermostat is in.
The fans only come on (half speed) if he a/c is on.
Replaced the thermo switch on the radiator.
Still overheats. This time i discover the switch doesnt come on because it doesnt get hot. The left side of the radiator is cold and right side is hot.
Flushed out the radiator - water moves freely through it so at this stage i thought must be the water pump.
Removed water pump - looks ok cant see any reason why it shouldnt work. The housing looks a little corroded but water path still looks clean.
I have flushed out the heater core and everything yet it still runs cold and engine still over heats.
Has anyone an idea what the problem could be?
The logic just doesnt work?
