Crankfoam
  • Crankfoam
    Started this about a month ago finally have some
    Codes
    01262
    00544
    16487
    16507
    16515
    16711
    16716
    00515
    00670
    I know what the codes are and judging by what ive seen i need to replace? The wastage bypass regulator valve or just check? And my camshaft position sensor is gone or i need a new distributor?
    Hey mate. Not really up to speed with what your issue exactly is. But your waste gate valve won't cause a non start. The camshaft position sensor however is a different story. It the ecu can't see the camshaft position it will spin but not fire. Going to go out on a limb here and say you're probably dealing with 2 separate issues and the timing of the two is just unfortunate. I doubt the slight overfilling of the engine will have caused this.
