hi guys whats the engine code on the aussie delivered audi 80 2.0L's? they're from around 93 and have "2.0E" written on the back (of the car). are they ABA motors? cheers.
Audi 80 2L engine code req.
They are 3A shortblock 2Ls. They are a bored out version of the 1.8 GTI Motors in the Golf 2.
The ABA is a longer bubble block. and a crossflow head.
New Beetles have a version of this motor.
I have a couple of ABAs just landed from America. Sing out if you need.
You can use a 2E 8v bottom end and an imported head, but you need to flycut the pistons.sigpic Camden GTI Performance. VW / AUDI Specialists
That's easy, you just need an old inlet and exhaust valve, some highspeed steel and a drill.Originally posted by Golf Loon View PostYou can use a 2E 8v bottom end and an imported head, but you need to flycut the pistons.
Braze the HSS onto the valves and grind a cutting edge on them, then you can put the head on the block and flycut the pistons one at a time Using your head as the guide.
just making room for the valves to go down so the pistons dont hit them at the top of the piston stroke. thats a good idea preen ill have to try that one day.
cheers brentonMK1 4door
MK2VR6
MK3VR6
Transporter
1st place, stock MK3VR6. Vw nationals 07
2nd place, mod MK2VR6. Vw nationals 09
and untold wrecks
U need put a stop collar on the valve stem so you dont cut the piston crown to far, and to make all piston cut outs the same ( close as you can anyway..Originally posted by Preen59 View PostThat's easy, you just need an old inlet and exhaust valve, some highspeed steel and a drill.
Lots of MK 1 Scirocco's...
Cheers,
Grant...
LOL. Where would you get either of them in Australia??Originally posted by Mischa View Postwouldnt it be easier to save the trouble and just use an aba block with abf head?sigpic Camden GTI Performance. VW / AUDI Specialists
Originally posted by Golf Loon View PostLOL. Where would you get either of them in Australia??Originally posted by Golf Loon View Post
surely a head isnt too hard to import?
anyway there goes my original idea of the 80 having an aba
2x Caddy, 1x Ducato
