Not often that I start threads on the forum but I did a bit to my own car today rather than someone else's...
Started off doing a Haldex oil and filter change. Just routine really, last done in 2009 IIRC and the KMs have been racking up driving to work since I moved to QLD.
Can't tell any difference with the car but I had the oil and filter in my cupboard.
The other job was fitting the FMIC that came out of my A3. If you have been on the forum a while you may remember the A3, it met a nasty end but is living on in a number of vehicles around Australia!
I have got some pipework on order which will arrive next week all being well. It's only a 10minutes job to get the bumper off, so hopefully and hour would see the side mounts out and the replacement pipework in.
I have been watching the intake temps on my phone using a BT OBD thingy. The sidemounts seem ok doing hard accelerations and keeping temps to within 10-15 degrees of ambient.
Whether the temps are like that on a track I don't know. During last summer though, heat soak was very evident when getting stuck in traffic and the it took a good few km to clear.
Hopefully the FM will help lots with that, plus some other things I am looking into as well.
I haven't got the dimensions of the IC to hand but I'll put them up later. It fits well with only the slightest of filing needed on the centre grille near the outlets. Chuffed.
A couple of pictures......
The intecooler dimensions are 450/300/75mm and the max 640mm at the outlets. It was made by ADRAD in Adelaide. There are a few dweaks in it from the prang it survived, if you look closely in the pictures the top mounts are a bit skewed.
