Hi brackie,
have you sorted out the braking problem yet? I hope so. If not, there was something in the thread that caught my attention. You mentioned that the old MC was 12mm and the new one 9mm. If you are using the same booster on both MC's then then there could be a problem. The smaller diameter MC displaces less fluid per unit of distance travelled but can generate higher pressures in the braking line per unit of force applied to the pedal. As the booster is applying extra force to supplement the muscles in you leg, it may be applying enough force to cause the smaller diameter mc to travel further.
If you have a 9mm mc then you may not need the vacuum assistance at all as you now can generate higher brake line pressures for a given pedal effort, the trade off being longer travel.
On the subject of brakes, i have several GLD's that are being prepared for roadworthy. I have measured the discs and i have thicknesses of 7-8mm. this seems to be very thin. Do you know what the wear limits are for the GLD's? Also, if i go to a wrecker, are there any other cars with better fromt brakes that i could adapt to the Golf?
Matt
Matt
