HELP!! A3 front door panel removal
  • HELP!! A3 front door panel removal
    Does anyone know how the hell you get the inner panels off the front doors?? Can't find any screws, so is it just a case of gently prising off (popper fittings) with a bit of brute force and ignorance.
    Chris
    http://www.vwgolfmk1.org.uk
    They just slide up and off.
    You have a screw at the top of the panel at the front and back.
    Then you need to prise out the trim in the handle after you take a small phillips screw out.
    In there you'll find 2 more bigger phillips screws.
    The panel should just lift up and off now.
    The door release needs to be unhooked and I think that's it.
      Cheers mate, will give it a whirl Monday when I'm off work. The door release is the issue, it appears to have popped off on it's own.
      Much appreciated
      Chris
