Major Dramas with Audi A4
  • #16
    Originally posted by Jmac View Post
    Hey mate, ill throw one in the mix, the fact that you are aving to disconnect and reconnect the battery is throwing me off the immobiliser slightly, my dad had a Saab 95 Aero doing the same thing as that and ended up being the MAF. Have you tried to disconnect the MAF and see how it behaves????? The description certainly points at immob as you mention it cuts out (straight away) A scan of the ecu in that case would pick up Immob reading Spool perhaps. Keep us in the loop bud, hope you get it fixed
    JMac
    This is definitely a possibility, but would likely turn the check engine light on. If it is the MAF, the fuel trim would be changing greatly and each time you disconnect the battery, it resets the fuel trim back to zero.
    Also could be possible there is a boost hose off. But really the car needs to be scanned. Also if you use Vag-Com, check measuring block 032 in engine before you clear codes or disconnect the battery. That is the fuel trim numbers and often you can tell what is wrong with just them.
    • #17
      Yeah mate thats right , the Saab i mentioned earlier did just that, we had to do all sorts of funny things to get it to run, disconnect the batt and the Maf, start up and reconnect the Maf!!! Boost hose yeah but this vehicles seems to run ok when going, bost hose would stall and stall and stall..
      Hope you can get someone to read them codes.
      Jmac
      Alba European
      • #18
        I have booked it into an auto electrician for tomorrow afternoon. He said he could check the fault codes for me and ill post up what we find. I tried the local audi dealer but they are booked out till monday next week... i really hope it is something relatively simple to fix though i doubt it..... Thanks for everyones help its greatly appreciated.
        Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
        Mk1 twin eng twin turb
        scirocco gti 2.1l 16v turb 6spd
        Audi A4 B5 1.8t
        • #19
          Well the problem pirsists, i had no luck with any of the local auto electricians or mechanics. None of the scanners will work with the audi. So its booked in to an audi service centre on Wensday.
          Audi A4 B5 1.8t
          • #20
            Do you have an aftermarket radio fitted? Unplug the connector to the back of it and scanners will work with the car
            • #21
              I sure do have an aftermarket sterio in it. Ill disconnect it and try again. Thanks Loon, much appreciated!
              Audi A4 B5 1.8t
              • #22
                You were right Loon, i disconnected the sterio and the scanner worked correctly.
                A fault code number 01177 came up with the imobiliser fuel pump relay but the relay was working fine... it was checked.
                Though a strange thing occured when the airbag fault code was reset, not only did the airbag light in the instrument panel go out but the orange car symbol light with the key through it also switched off along with tachometer and speedometer.
                Also the fault code that came up previously has now gone and the engine management system could not be checked by the scanner.
                The car still requires the battery to be disconnected and reconnected to start so its off to audi tomorrow.
                Audi A4 B5 1.8t
                • #23
                  AHHH!!!!! disconnect your ABS pump multi plug and try everything mate, starting , scanning the lot, if that works then the k line ins down in your Abs pump and will need to recon. Just had one done, Abs down is the missing link and is common mate. Worth a try, disconnect it and see if it makes any difference. Might not make sense but try it.
                  See how you go.
                  Jmac
                  Alba European
                  • #24
                    Thanks Jmac ill try it, its strange how things interconnect in the system.
                    The local audi guys who have only been servicing audi for a couple of years told me the ECU is the issue today and to get a new one will cost soooo much!
                    Audi A4 B5 1.8t
                    • #25
                      I disconnected the ABS plug and you were right Jmac, it worked! Starting was fine though i havn't scanned it again yet. So where is the K line in the ABS pump located? Whats it worth to recondition? Thanks Jmac
                      Audi A4 B5 1.8t
                      • #26
                        It would be nice if it were in the wire going to the pump.
                        If the worst comes to the worse, i have a couple of those ABS pumps mate.
                        • #27
                          Seen that a few times now and no scanner will find that one!!.So glad you gave us the last piece of the puzzle with your last post. What happens is the contacts in the ABS pump break contact, K line goes down and gives the system a spack attack. Its around $500 to recon the ABS ECU, but i would check your pump number and take Matt up with the second handie.
                          Jmac
                          Alba European
                          • #28
                            YEHAAAA!!!!!!!!!!!!! thats the one mate!!! Seen that a few times now and no scanner will find that one!!.So glad you gave us the last piece of the puzzle with your last post. What happens is the contacts in the ABS pump break contact, K line goes down and gives the system a spack attack. Its around $500 to recon the ABS ECU, but i would check your pump number and take Matt up with the second handie.
                            Jmac
                            Jimmy diagnoses using 'the force' !
                            I would like to see inside that ECU. What do they do to fix them Jimmy?? Just soldering/cleaning up connectors? Or are components replaced?
                            • #29
                              I know most of the time its soldering in most of these components, im sure they replace a component too, ill ask that very question. I do know the ecu gets function test before return. Some companies claim u cant, these guys endorse the unit with a guarantee, sticker date the lot. I just had one done on an A6 and was the first time getting one done, was a bit nervous to be honest but result was impressive.
                              Jmac
                              Alba European
                              • #30
                                Crack the unit open and resolder the joints for the bush mchanic cheapo fix Marty
