Hello fellow forum members... Quick hello.
Im new here have a few Vdubs t3,t4 type 3 coupe and just recently a 02 Passat for the wife.
Im actually looking for a abs module to suit it, I did a repair on the module in it but after a pot hole my solder joint has obviously come loose again and the ABS and Flashing red brake warning light have come back.
Im sure this site is a wealth of information..
 Also there is no accual clamp arrangement to hold the battery down so the battery can move a little from side to side and back and forth. Im guessing this is why the problem was random... I donno will clean and tighten up the battery terminals and see how it is in the morning for the drive to work.
						 so now im waiting on the ts housing etc and researching how to check the cam timing so i can be sure when I put it back together.
