Golf mk5 Aftermarket Fog Lights
  • Golf mk5 Aftermarket Fog Lights
    Hi Guys,
    im looking to install fog lights on my Golf mk5 2006. My car doesnt have fog lights at the moment and just has a blank grille. I read that its possible to install these using a relay and an external on/off switch. Anyone here done this before? I also found this kit on ebay which looks the part, its got the grille, fog lights, relay and external switch all included. Do you think its got everything needed for the installation? Excuse my inexperience FOG LIGHTS LAMPS GRILLES SET FOR VW GOLF 5 MK5 2003-2009 & WIRING KIT A18 NEW | eBay
    Nicky
    ->Forum: Mk5 Golf & Jetta
    Past - '95 VW Golf MK3 VR6
        Just a heads up, you might be able to find parts you need in the selling section. It's often a lot cheaper and not to mention faster and easier than having to buy from overseas.
        P.S Welcome to the forums!
          Thanks The only problem is I'm from Malta in the middle of the Mediterranean haha :p Unfortunately overseas is the only option since nobody stocks them here in Malta. Iv posted in the the MK5 section on the forum as you said, waiting for someone to reply before I go ahead and buy the kit. Thanks mate
          Nicky
            I fitted fogs to my R32 and wired them into the cecm and fitted the correct headlight switch so it looks and acts as original, including bulb out, dimmed for drl and turning lights. The relay option is ok if the cecm is the wrong type but they are easy to swap.
            08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
            http://photobucket.com/gregsr32
