T4 Gearbox /Transmission. What is compatible?
  • T4 Gearbox /Transmission. What is compatible?
    Hi Guys
    I am new to this forum and would like some help with finding some information in relation to a compatible gearbox.
    I have a 2002 Transporter T4 powered by a 2.5TDI. The transmission is an auto and has died. I am looking at replacing it as opposed to spending $6k to recondition. The issue is how do I find what gearbox is compatible to bolt straight in? I have heard that the manual boxes were just a little more reliable, so that may be a good option.
    Does anybody know if there are product code numbers on the box and can I refer them to some compatibility list? (ie what engine goes with what transmission etc)
    Your help is much appreciated.
    There is some info in this link. The 02G is the gearbox you would need because it's stronger than the 02B that is used in the petrol models.
    The 02G TDI Gearbox - VW T4 Forum - VW T5 Forum
    Numerous Mk1 Golf diesels
      Great Info.
      Thanks very much.
        Although an 02B gearbox, this may also be of some help.
        VWVortex.com - DIY Auto to Manual transmission conversion + 5th gear set swap
