Hi guys,
I am struggling to orientate myself around this site. Before joining I came across some DPF related posts from you guys which caught my attention, and also some tune info and also talk of flash tunes here and there. I now cannot find them any more.
I have a 2007 128Kw transporter, with 211,000 Klm's. I am not new to diesel but am to new diesels.
I bought the van without much history and hence no Idea of it's service life, stupid really but being somewhat mechanical I just knew it was OK when test driven.
Have done several oil and filter changes at 5000 Km's intervals to flush through so to speak and for peace of mind.
I must admit the van is fantastic in every respect except one, it's economical, very reliable and fast, does not burn oil, between services, but now after 10 months I understand the van a lot more, and the DPF system.
I do mainly 80 Klm freeway trips every day M5 back and fore to work, but it seems that the DPF regens every 200 Klm's.
I have seen a few posts regarding deletion of the system and then tuning.
It's the tuning and deleting the dpf from ECU I am interested in. Can i get this done in Australia, the UK seem to have people everywhere that can do it.
I here you all saying oh no not another one
Sorry. Also I am getting a vibe that there possibly could be a problem with the DP switch?
Could someone answer my sceanario for me. Remove dpf filter, smash out inside, replace. With nothing inside and if I loop out the DP switch, It will never regen again if it does not get signal to do so, would that work???
Any info greatly accepted, fed up with the flatspotting, surging, smoking out the rear, ( god help the people behind me when it regens, probably 1000 times more carconagenic than just the soot, blowing out, chemicals at high temperature take on a completely different state)
Sorry. Also I am getting a vibe that there possibly could be a problem with the DP switch? Could someone answer my sceanario for me. Remove dpf filter, smash out inside, replace. With nothing inside and if I loop out the DP switch, It will never regen again if it does not get signal to do so, would that work???
