Clutch slipping
  • NSW Clutch slipping
    Does anyone on the forum recommend Exedy clutch kit found one for $315 compared to $450 for VW OEM?
    No idea about the exedy, but you can get an OEM one for similar or less than $315 from some of the local aftermarket suppliers.
    What engine is yours?
    I got a 210mm SACHS kit with the large input shaft disc for $300ish a couple of months ago. You can get them cheaper
    The LUK ones are sometimes cheaper.
    Try Tooleys, HSY or quite a few others. good luck.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
      It is the 2E engine thanks for the info I am looking forward to getting it sorted.
