Replace mk3 VR6 engine with the all new MK6 TSi golf R engine...
hi people,just wondering if anyone has done a conversion with a mk3 vr6,removing the engine and installing the all new golf 6 R TSi engine in the mk3..is it possible?
yeah sure is mate..got time,money wouldn't be an issue as i have a golf R that took a beating from the back...picked her up at an auction for 4k..would love to have the tsi engine in my vR6...
---------- Post added at 05:02 PM ---------- Previous post was at 04:56 PM ----------
@STU i will not be changing the vr6 engine on mine,i will be getting another mk3 and transferring most of the stuff so il have the best of both in the mk3
the vr6 is unique,sounds like its on steroids,but the tsi engine to me would be the ultimate conversion
I'd say your biggest hurdles would be transmission / drive (4WD -> 2WD), ECU and associated electrics. AFAIK, these things won't even turn over unless all the critical systems on the CANBUS check out (like ABS/stability control and associated kit).
Yeah electrics would probably be quite tricky. Could you just run it on standalone management and not worry about all the original things? When it comes to that sort of stuff I have no idea, never really looked into it.
I imagine it would fit, probably need to fabricate some special mounts and whatnot. No idea what youd do as far as gearbox etc. I assume you wouldnt be attempting to convert the mk3 to awd, as that would be an absolute nightmare of a job. Anything can be done though with a bit of imagination, a handfull of money and a hell of a lot of spare time/patience. Id love to see this be done successfully, may aswekk build up that R motor while its out and such too and make it into a crazy beast of a car.
Unless you know something I dont there isnt a stand alone unit out there that can run FSI and be compatible with the Can-bus systems of the engine .
---------- Post added at 12:25 AM ---------- Previous post was at 12:25 AM ----------
