RNS510 weirdness
  • RNS510 weirdness
    hi folks
    I was wondering if anyone else got strange directions from their sat nav IE " continue on this road for a long time"
    also the systems developed a lisp , could it be possessed?
    also the system holds phone calls even though both I and the caller has hung up as a result I cant get the nav screen back, I have to stop,turn off the car,remove the key then restart to get my nav screen back
    Sometimes they play up so give it a reboot.
    Hold down the <rewind>, <forward> and <i> key next to the DVD slot to reboot. If you are driving while you do that, the last position will be where you pressed the keys, so it will take a few minutes to find itself.
    I have to reboot mine occasionally, typically, after shutting the car down then 10 minutes later restarting, there is no navigation displayed in the MDI. A reboot fixes that.
    A reboot doesn't fix the voice though.
      Originally posted by gorilla View Post
      hi folks
      Only yesterdayi had mine on FM and i kept getting these ding gongs going off ,i noticed the TP was flashing every time it did it thats what i call weird
        actually that's another issue the nav turn by turn doesn't display on the mdi
          the plot thickens
          one theory is that because the car has both a kumfatec Bluetooth set up and a sat nav system which also has Bluetooth, there may be a conflict, I took it the the workshop at Chatswood Classic today, no fault codes appeared
            You can turn off the TP system in the setup menu. When I experimented with mine, I got the dings too when the signal level dropped off (away from Melbourne).
            "continue on this road for long time" is standard instruction. No turns in the near future.....
