G-8VXWWTRHPN T4 Window Winder - VWWatercooled Australia
T4 Window Winder
  • T4 Window Winder
    Hope somebody can help me here! The window (manual, not electric) on my 2001 model T4 van is stuck....closed.
    I have removed the small plastic viewing cover on the door and can see the problem, but I need to remove the door lining to fix it. I have also found instructions on how to do this. My problem is that I cannot remove the window winder. It does not have a cover with a screw behind - as described in the forum. I have tried squeezing the 'collar' between the winder and the lining, as somebody described, but without success. Any help would be greatly appreciated.
    It has been a while since I have had my T4, but from memory to take the handle off, at the base of the handle where it sits next to the door panel, is a slide catch, best way to explain it, you push away from the handle and it should unlock it and the handle can come off. Copy and paste this link, it shows you how simple it is. "http://www.youtube.com/watch?v=Ak11vM-Jyg8"
      After wandering around swearing for a while, I had another go......
      With the winder handle facing up, I pushed the collar down....presto!
        Thanks for your help transporterq!
          Superb Choice For Male and Female-Cheap Nike Air Max Shoes
          When you find yourself going towards the searching mall to investigation the exceptional shoes which could offer you the best comfort and ease, among the list of well known model won't ever be overlooked. It is actually Nike. It normally supply both the manner and also the comfort and ease into the wearers. Putting on this sort of a pair of footwear, you might really feel pretty proud and self-confident. More more, if you need to possess a extra perfect overall performance from the sports discipline, the sequence of Nike Air Griffey Max I or Nike Dunk Significant you should not skip. Should you be heading to seek out a pair of high-end sneakers, you need to surf on-line to have far more assessments with regards to the sort of sneakers. There are numerous evaluations on these designer shoes like Nike Air Max or other Nike sneakers. Therefore, you can easily know which a person is in shape for you ideal, therefore you will never haven't any reason.
          The branded footwear always give the superb ease and comfort for the legs and the feet to maintain them within a relaxed statement. As an example, Nike Dunk SB might help one to dunk by providing ample cushion. As well as Nike Air Max shoe are able to present the sportsmen with lots of help and traction in the sports activities arena, too. A better aspect of designer Cheap Nike Air Max sneakers would be the lightweight that may make the runners even forget there're donning footwear. It is known to us that girls do less activity than guys. On the other hand, are you aware the triggers of your phenomenon? Whenever you know the motives, you will experience ridiculous. There are many shoe producers only develop men's footwear within their factory, so women haven't any acceptable sneakers to have a sport. Because of this, the Nike organization commenced to supply ladies the very best sneakers, especially designer sports activities sneakers.
          The renowned brand sneakers normally give women the help they will need so as to show their sports overall performance flawlessly. The good traction supplied in running or in enjoying basketball is often uncovered within the Women's Nike AirMax shoes. Hence, gals will acquire sufficient safety for their feet that guide them have a very very good handle though there're operating. It's the essential demands that sports footwear ought to supply. Due to the tremendous quality as well as the formidable longevity, you are able to be expecting which the well-known brand name Nike Lebron 8 shoes have the capability to very last for some time of use. For the humanized structure, the kind of footwear can shield your feet through the distortion much better and more safely.
