Bora 2000
  • NSW Bora 2000
    Just bought a bora 2000 2.0L manual, very happy with the car performance even for its age
    Looking for new/used pair of headlights for my Bora? any idea
      Welcome
      the 2lt bora is the fastest car on the road (id know, i have one)
      ok so there not the quickest, but strong and very reliable.
      whats wrong with your headlights?
      I have a set im about to pull out of my car to suit a 2lt, they need refurbishing (plastic lenses go nasty), but don't have broken clips like a lot of other second hand ones
      Bora gone
      Vento VR6
      MKIV GSW TDI
      7P Touareg TDI
        My headlights seems to have the same problem as yours, the plastic lenses aren't clear at all. Do you have any idea?!
          if that is all, you can fix them by sanding, polishing, and sealing with a UV protection. Check under the detailing section i think and look for DMS Dan i believe.
          i purchased a kit from autobarn for ~$40, has everything in it, although the sand paper seemed to only just make it through the second light, and the polish wasnt fine enough.
          If you take your time they will come up close to brand new.
          Bora gone
          Vento VR6
          MKIV GSW TDI
          7P Touareg TDI
