HI!
  • HI!
    QLD:HI
    dont have my vw yet,still looking.i'm tossing up between the passat 3c fsi & the audi a4 b7.the passat seems better value but i like the look of the audi slightly better.going to try an audi tomorrow then hopefully if i can find a passat locally do a direct comparison.the passats come with the tiptronic dont they?if thats right i prefer it to the audi multitronics,which i believe is a bit fragile at times.i would need to go quattro in the audi to get away from the multi trans & i then loose a bit of get up and go.i will be getting a ecu upgrade either way so this will help but i am coming from a calais v 6 litre with some work so i do wont a little help.is it worth upgading the downpipe off the turbo
    7 replacing the cat with a high flow item?i will probably improve the air intake as well but that will be the limit of performance mods.some springs/shocks & rims will be the other mods.any advice on these items will be happily received.
    cheers
    warrick
    sigpic2011 3CC 3.6 V6. 19X8 CADWELL RIMS, K & N FILTER, EXHAUST TIPS,DBA SLOTTED FRONT DISCS,ATE CERAMIC FRONT PADS.
