G-8VXWWTRHPN Hello from US - VWWatercooled Australia
Hello from US
  • Hello from US
    Name is Dave
    Was directed here by hits on my web site. I manufacture VW ball joint extenders and bump steer kits, and like to keep up on what folks are saying about them. Going through the forums is the main way I get feed back from people who have purchased them and those who are thinking about it. Plus it is interesting to see how the forums vary from country to country.
    Good to be here.
    Welcome aboard, your products have indeed created a lot of interest here.
    Might have to buy some myself one of these days.
    Would love to see a MK1 camber plate in your product line up.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
      Welcome Dave.
      I have a feeling since the recent influx of super dooper low coilovers have hit our shores and lowered many of our cars, alot of us have become very interested in your products!
      We may even have to arrange a group buy, for those genuinely interested parties.
        Welcome Dave,
        Glad you joined the forum.
        We were talking about this topic last night as i was interested to buy some ball joints from you guys.
        Know that you have joined the forum it is alot easier to buy the ball joint extenders.
        Cheers.
        Golf GTI 1980
        Golf GLS 1979
          Welcome, by the sounds of the first 3 posts you PM box if going to be full alot of the time.
          Originally posted by Preen59
            Welcome Dave. Have heard great things about your products, though I also hear about complaints that there isn't anything for the A3 chassis VR6! I wonder if there's any chance of developing products for it?
            Present: Mk3 Golf variant.
              I'm in
              I'm in for any MK1 front end alignment parts (camber plates) but my MK1 will be only lowered slightly.
              Spark ignition is a threatened species
              Biodiesel is the best emission control money cant buy
              MK1 5 door Mexico Beige 5/79 Golf GLD 1.5
                Im with Ray on this one. Would be great to see something made up or adapted to fit the MK3 chassis, something I would be keen on to get the car setup better
                  I have a design for the VR6, but the tapered ball joint pin adds quite a bit of complexity to the extender,and have not figured out how to make them at a reasonable cost.
                  I am out of stock on the extenders 17MM and 19MM, but am making a production run which with heat treat and finishing is out about 4 weeks.
                  Dave
                    Hi Dave, good to see a manufacturer here,
                    Can you please specify if your products are designed for road going use, As i would think the majority of extender kits sold here will end up on street cars.
                    I did notice the disclaimer at the bottom of your web page, but i think it needs to be bought to the attention of potential purchasers for everyones safety.
                    Lots of MK 1 Scirocco's...
                    Cheers,
                    Grant...
                      Welcome aboard!
                      Nothing to see here...
                        Road or track
                        The parts that I manufacture are primarily for track use. From the very first I know there are many of the extenders that are used on the street. What I tell people is that, the parts have not been given a 100,000 mile life test on the street, I have not tried driving one through a 6 inch deep pot hole in the street.
                        I do have parts that have been running in road race environments for up to 10 years with zero failures.
                        My main concerns about these parts being used on the street is: Parts on street cars tend not to be checked very often, torque on bolts/nuts should be checked periodically, and the radius between the pin and the body of the extender is the most highly stressed area. It should be protected from damage and rust.
                        Even though I have been manufacturing and selling these parts for more than 10 years, with zero failures, I still have a concern about liability issues.
                        Anyone can read the specks on the extenders, by going to the catalog section of the web site. www.pmwltd.com
                        If there are any questions or concerns about any of the products feel free to ask.
                        I do make Caster/Camber assemblies that will fit on the rabbit tower, but have sold out stock and will not make any until I am done with the extender run.
                        Dave
                          What type of design are the camber plates Dave?
                          Golf GTI 1980
                          Golf GLS 1979
                            There are a number of pictures of the caster/camber assemblies that I make, on the website. On the photo page there is a picture of an RX-7 installation, the Rabbit would be the same layout. When you loosen the 6 bolts on the top clamping ring, that allows the slotted plate to rotate 360 degrees, to set any combination of caster or camber. Then loosening the bolts that hold the bearing for the strut rod, you can move the bearing in the slots to set the amount of caster, camber or both.
                            Dave
                              hmmm very nice engineering
                              EP Solo II '84 VW Rabbit converted to double AArm front suspension
                              Check this out, I take this is for racing not street?
                              Would it be OK for a street car?
