Hi, think this has been covered before but: Connected my boat trailer to my new V6 TDI Touareg and the lights flickered (lcd's) so I connected to my box trailer and all worked except blinkers come on for Brake lights, (both trailers worked fine on other cars) any suggestions??
The lights are not LED's, all lights on trailer are normal. And there are the normal number of lights on the trailer, two tail-lights, marker lights across the rear cross member of the trailer and side marker lights on each fender. Trailer is a boat trailer.
No Commercial Advertising. Please Refer To Forum Rules...
The lights are not peimar led lights, all lights on trailer are normal. And there are the normal number of lights on the trailer, two tail-lights, marker lights across the rear cross member of the trailer and side marker lights on each fender. Trailer is a boat trailer.
I do have schematic diagram for led lights but not normal one
If it's the same as mine (MY 08 ) then you need the LED converter box. Available on eBay for about $260 or from the dealer (I have been quoted $214.00 from the dealer).
Wiring of the V6 TDI Touareg is not LED friendly. You need that converter
