Hi All,
Just picked up the Jetta and the previous owner has no idea if he used the red or green coolant and the fluid is below the minimum line so I can't see what color it is. I know you shouldn't mix the red or green coolant together that could cause issues, so any idea where the plug is so I can do a flush of the system?
Should I use the red or green coolant or does it not matter?
