Honda CRX 1988 with SIR front, SiR tail lights and other bits and pieces.
Selling because of lack of time energy and I have bought a new car so I don't have time for my track project anymore. Instead im looking just for a weekend car for me The car was always stored in the garage and is in very good condition considering age. Perfect for a car enthusiasts as most the hard work (engine conversion). I have recently replaced all fluids and done a service. Brakes are excellent and tyres have roughly 85% tread. It was always looked after properly. The car has been rego'd in NSW and comes with Mod documents (it previously had a b18 engine in it) The car has been regoed in VIC with the B16a.
Now the bad bit. The wiring from the previous owner is dodgy at best it was a rush job and to do the car justice should be redone. I have a spare engine loom what will come with the car as part of sale to help the new owner out. It also comes with a stack of spare parts.
Honestly if you had time, energy and space you could get this on the road or finish it and make a fun track day car.
IF THIS DOESNT SELL I WILL PART OUT.
WHEELS IN PHOTO ARE NOT FOR SALE WITH CAR (THESE CAN BE INCLUDED FOR EXTRA)
Exterior
ED9 Shell Completely Straight Body, no dents it's perfectly straight with SiR Front End
Shaved Engine Bay and Wire Tucked,
Fuse box re-located, battery re-located to Boot for clean look
Recent Satin Black 2Pac Paint Job with Gloss 2Pak black roof
SiR Hood (painted in Satin Black, same as body)
SiR Rear Tail Lights
Spoon Power Mirrors
Tinted Windows
Removed Rear Wing & Wiper Deleted
Electronics & Interior
OBD0 B16A ECU
Oil Pressure, Oil Temp & Water Temp electronic gauges
Safety 21 Rear Half Cage
Engine and Drivetrain
Stock Standard 89' EF9 SiR JDM B16a (118kw) with Power Steering, done 128,000 Km’s – Compression of 200psi across all cylinders
4.4 Final Drive EF9 SiR Y1 LSD Cable Gearbox
PP. Polished Type R Throttle Body
Short Ram Intake with 3A Pod Filter & Custom Air box
Samco Yellow Radiator Hoses
Rocker cover Painted Yellow to match
Online Performance Engine Mounts
B&M Pro Race Short Shifter with Energy Suspension Shifter Stabilizer Bushings
Exedy Heavy Duty Clutch
SiR Front Brakes, Slotted Rotors
SiR Rear Brakes, Slotted Rotors
Stainless Steel 4 – 1 Extractors
2.5' Custom High-Flow Cat-back Exhaust System
Top Gun 8.8mm Leads
NGK Plugs
Suspension & Wheel
Stockies with good tred
Skunk2 Adjustable Front Camber Arms
KYB Sport Shocks & (Unknown) Lowered Springs – Not chopped
Saner Front Sway Bar
Rear Strut Brace
Misc.
EF9 SiR Dash and Centre Console and cluster
Factory Option Climate Control Unit
EF8 SiR Map Lights
EF8 SiR Door Cards
Central Locking
2 Way Pager Alarm & Immobiliser
Contact:
Dan - 0422611803
Price:
4000 - Will swap for a MX5 or VW MK1 Golf or Dirtbike
Pictures:
Exterior
Spoon Power Mirrors
Tinted Windows
OBD0 B16A ECU
Top Gun 8.8mm Leads
NGK Plugs
Suspension & Wheel
Rear Strut Brace
Misc.
EF8 SiR Map Lights
EF8 SiR Door Cards
Central Locking
Contact:
Dan - 0422611803
Price:
Pictures:
