Hi Everyone,
I am after a bit of technical advice.
I have a MkIV 1.6 Manual which seems to have developed a small fluid leak somewhere about the hose into the steering box (passengers side). I think its call a "banjo fitting" . I have checked the fluid level and is still on full so the leak has only just started and is really quite small...but it is a leak.
Has anyone had a leak from around that area and what was the fix?
Then I thought...if I wanted to check the oil level in the gear box...where would I do it. The answer...I have no idea.
Can anyone help with the location or method of checking the gearbox level.
