Hello Guys,
I have a 2002 Skoda Octavia 1.8T with only 56,000 kilometers ( I just use it to go from home to my work and them back to home)
I have a small problem with my coolant temperature.
Both Coolant fans are working in slow and fast speed
AC is working OK and is cooling perfectly
Fuse over battery are OK and not melted
When I am at stop light the coolant temperature rise a little bit from 90º to 95º (Please check the photo) It does not rise more than that.
When I begin to drive, the coolant temperature go back to the middle (90º)
Also, one day that I saw the temperature in 95º, I turn off the engine, wait a little and then start again the engine........ The temperature goes to 100º and a few sec later go back to 90º
I was thinking the Termo Switch was not working but I open the hood and I see both fans are working in hi speed and then they cycle to slow speed.
This problem happened after I took the car a weeks ago to the VW Dealer to fix a small leak on a coolant hose 1J0 122 109AQ that is near the coolant reservoir and when they gave me back the car, I notice they put me in a bag the damage hose part + two empty G12++ Coolant 32onz bottles.
I was curious because I am pretty sure when the replace that small hose some of the coolant loss on the floor and they need to add more but I was think that maybe one bottle plus water was enough...............So when I ask the mechanic guy, he says he put the 2 bottles and they do not mixed it with water and that this is OK
Here in my country the weather is very hot. I know the G12++ Coolant has to be mixed 50/50..............Can this be my problem that the coolant temperature rise a little........ Or this can be a symptom of a water pump that the plastic impeller is going to fail
THX
Isaac
THX
Isaac
